Results 1 to 3 of 3
    All all exhausts doomed when RSR Downs are installed?
    Hi all,
    EP3 with stock exhaust and RSR Down springs.
    Pretty much only one finger of gap between tire and guard.
    I really really really do not want to revert to stock suspension so the other solution is to replace the exhaust.
    My bottom line question is...
    Are there any aftermarket exhausts with more ground clearance than stock?
    Thanks!
    Using Tapatalk
    Most of the time, The lowest point is the resonator/s and the catalytic converter.
    So any exhaust system will help with clearance. When you get it installed ask them to do an exhaust tuck aswell. Helps a lot
    Exhaust tuck! Sounds like an awesome idea. I'm considering an exhaust tuck on the stock exhaust. Possible?
    Using Tapatalk
