Results 1 to 12 of 14
    Sep 2003
    datsun 200b
    Putting an b18c into an ek4
    G'day peeps
    I've been trying to search up and down, trying to find out what is involved to swapping a b18c (96 JDM ITR) replacing the b16a I currently have
    A few questions I wanted to ask was
    What will I need? Can I use my existing loom?
    Thinking since I'm already running a b series motor, unhooking the engine loom from b16a and throwing it on the b18c shouldn't be a problem
    I know the ek4 is currently an obd2a and the JDM 96 spec itr is also obd2a
    Should I be running into any problems? Will I need to run a conversion harness? Ecu will be hondata
    Kenny
    VTEC+Turbo=dirty underpants
    Use the existing loom.
    Literally bolts in exactly the same
    Sep 2003
    datsun 200b
    Thanks Benjamin! I thought so, but I'm just abit iffy, just use the existing driveshafts aswell? Gearbox is from a audm itr b18c7, has spoon 1.5way LSD and ogura 309d clutch
    If I was to run an ecu (standard) what ecu can I use to run it for the time being?
    Yep same driveshafts.
    I'd use the standard ECU - it will run fine for the 'mo
    Sep 2003
    datsun 200b
    The engine I'm getting doesn't come with the matching ecu
    Cause I'm wondering Benjamin, at work I have a p73 fr an integra, reckon it'll be possible to fit?
    Jan 2013
    Brisbane, qld
    98 ek b18cr
    Off the top of my head, it should all be identical. As long as the engine is the b16a2, which I believe the b18c jdm is.
    Driveshafts, mounts, loom will all be the same.
    Jan 2013
    Brisbane, qld
    98 ek b18cr
    The b18c will be a p73.
    Sep 2003
    datsun 200b
    but p73 from audm or JDM itr ecu's should both work correcT?
    Jan 2013
    Brisbane, qld
    98 ek b18cr
    Yep. P73 is the same. As long as the engine is the type r red top.
    Jan 2013
    Brisbane, qld
    98 ek b18cr
    By that I mean b18cr or b18c7/c5. Both from the 2000 ITR
    Nov 2009
    Civic EJ8
    Why u goin engine swap kenny??!?!?!??!?!?!!!
    What happened to going turbo? lol
    I <3 BOOST! D16+T SOHC
    Sep 2003
    datsun 200b
    Don't worry Barry! I'll turbo this motor just wanted that extra 200cc's for now
    Have big big plans for this puppy, engine will be going in next week
