Results 1 to 6 of 6
    May 2014
    portarlington vic.
    97 legend
    another abs light on.
    g'day, my 98 legends abs light is on all the time. just got the car from brother inlaw
    who is overseas and can,t ask why relay is missing. have bridged the relay and can hear motor going. i guess it was taken out for a reason and not sure if it's safe to try a new one. any ideas please.
    Well why would he remove the relay
    Why would you bridge the connections
    By doing so you may have burned out the ABS pump.
    You normally get ABS lights when there is an issue with the ABS system.
    This could be as simple as a dirty ABS sensor.
    Green block gangster Array
    twin GX160's
    Quote Originally Posted by Grayfox View Post
    Dirty WSS don't usually cause faults, Bridging the pump relay momentarily wont harm the pump either.
    Best to read the ABS ECU for fault codes to determine the fault. If the pump relay is missing then the ECU will detect the pump is not able to run and failsafe the ABS system.
    May 2014
    portarlington vic.
    97 legend
    thank you , i only bridged it for 2 seconds. i see a plug with it looks like 3 connections. is the one to get codes. it hangs down under the glove box.
    twin GX160's
    you need to find the 2 pin SCS connector
    Jun 2012
    Perth
    CD5 & GE6
    Its a blue connector
    www.OzAccord.net/forum
