Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: bonnet issue
    Mar 2014
    Sydney
    EK BRITTANY
    bonnet issue
    anyone know how to open a civic ek bonnet without using the actual latch that is inside the car. need help as it will not open.
    Oct 2004
    www.alibaba.com
    porsche boxster
    can you feel it pulling the cable?maybe snapped
    Jan 2011
    Dunhill
    Winfield
    get one of these and pull on the broken part to open bonnet
    common problem on ek civics
    Dc2r and em1 only good if you work at McDonald's, s2k good for order food in McDonald's
    deal with it m8
    Mar 2014
    Sydney
    EK BRITTANY
    No the cable and everything is perfect in the car, it's just the situation that is happening requires me to get under the bonnet of my car without the key
    Oct 2004
    www.alibaba.com
    porsche boxster
    hmm without breaking something not sure.
    sacrifice the grille
    Mar 2014
    Sydney
    EK BRITTANY
    I need to open this bonnet without causing damage, I've managed to find the cable that runs to the bonnet latch (on driver side ), I've pulled down the guard as much as it can on top if the wheel and put vice grips / multi grips on the cable and tugged on the way it would go to open , all it did was pull the casing around the wire and when I took the grips off, it fell like a I had crushed the protective casing around the wire, I need a way to open this, I can't get under the car because it is parked in a awkward position and I can't jack it up, suggestions guys AND smashing my window will not be acceptable
    •CRX• represent Array
    Nov 2003
    CRX+CBR250RR
    so for you to say smashing the window to get inside is not acceptable.
    why don't u contact RACV so they can get you access into your vehicle without damage.
    and they you can access the bonnet latch.
  8. #8
    Jan 2011
    Dunhill
    Winfield
    pics pls
    deal with it m8
  9. #9
    Mar 2014
    Sydney
    EK BRITTANY
    It's to late to call now isn't it? I'm starting to panic now
  10. #10
    Jan 2011
    Dunhill
    Winfield
    Quote Originally Posted by MAZ.827 View Post
    I don't think so I thought that their roadside assist was 24/7
    deal with it m8
  11. #11
    Dec 2011
    Launceston, Tas
    '77 Civic
    roadside for them is 24/7.
    This does sound sketchy. Certain locksmiths have after hours services, too
  12. #12
    Mar 2014
    Sydney
    EK BRITTANY
    i was refused service by the nrma because of some shit...............................
    cant get them to come out for now
    my keys are stuck under my bonnet for the time being i need them out asap
