Hey guys, The dreaded check engine light has appeared on my '96 DC4 Integra. I saw a method on you tube where you can pull engine codes by bridging the port with a hair clip and causes the check engine light to flash in sequences allowing you to find the issue. (For OBD1 only)
Anyway, Im super confused, my car is A 1996 and I've been told that cars had to be equipped with OBD2 in that year, but others have told me the laws came in later to Australia, and some cars (such as mine) didn't receive OBD2 till later. My issue is how can I tell if my is OBD1 or 2?
I took some pictures of the wiring where the ports are apparently located, hopefully someone can help.
^ The blue plug which Iam meant to bridge
^This is where my OBD stuff is located
Hopefully these pictures help to the right person. Thanks!
