Results 1 to 10 of 10
    Feb 2014
    Sydney
    dc2
    dc2 itr driveshaft cv problems....
    The drivers side inner cv boot is throwing grease out at high rpm. I've replaced the boot and clamp but to no avail. Any ideas?
    Pit bitch for No. 39...
    Green block gangster Array
    May 2004
    twin GX160's
    If its still leaking grease then you have done up the clamp tight enough or you boot is not the best fit. Did you use OEM or aftermarket ?
    Feb 2014
    Sydney
    dc2
    Aftermarket, I've tried 2 different brands. Don't have any problems with the other 3 I replaced at the same time.
    May 2004
    twin GX160's
    then your clamps are to loose,
    did you let all the air out of the boot before clamping it ?
    Feb 2014
    Sydney
    dc2
    Thanks, but it is NOT loose. As I said, the other 3 are fine. You cannot move the boot at all & I've ensured that there is no trapped air.
    Oct 2006
    Melb
    P1.5 460F/350R
    Quote Originally Posted by 39erman View Post
    how did you clamp it?
    S P A M | W O R K S
    Feb 2014
    Sydney
    dc2
    Using the metal bands. If I was doing it wrong it should be a problem on the other 3 boots that I replaced, so thats why I'm posting here to get some other ideas. Maybe the machined groove is worn/out of spec? Dunno...
  8. #8
    Oct 2006
    Melb
    P1.5 460F/350R
    did you use this to tighten the metal clamps?
    S P A M | W O R K S
  9. #9
    OP did u make sure the groove is grease free when tightening?
    A little trick to prevent weeping is smear some liquid gasket or similar around the band end and onto the cup itself. If there is a slight chance of a weep this will seal it up
  10. #10
    Feb 2014
    Sydney
    dc2
    Hmm, yes I clean up both faces with acetone. Might try the silcone method thou.
