Results 1 to 10 of 10
Hybrid View
    Feb 2011
    Geelong
    EG4 B18CR
    Help eg4 b18cr swap vtec not working!
    hey guy i got eg4 with jdm b18cr swap vtec is not working!!! (old engine is D15b7 injectors)
    Stock B18CR with running P30/ Neptune ECU chipped by: ECU-MAN
    mods on engine: Skunk 2 intake monifold with stock CTR 62mm TB
    - Spoon spark plug leads
    - Skunk 2 fuel rails
    - PLM Header
    - Customs 2.5" catback
    - Samco air intake
    now throwing Code 6 20 and 23
    I have run the three (four including ground) myself.
    - VTEC Pressure Switch (red/white)- to D6
    - VTEC Pressure Switch (GRN/BLK)- to ground
    - VTEC Solenoid (GRN/YLE)- to A4
    - Knock Sensor (RED/BLUE)- to D3
    Currently, a rev limiter is kicking in a 6200rpm and lose power all the way to 4000rmp or let's the car rolling on N and than back up agian, and VTEC is not working.
    Can anyone verify what wrong?
    1) Will the three missing wires / incorrectly wired sensors, cause the ECU to limit the rev to 6200?
    2) I thought a B18C revved til 8200, obviously if the wires are wrong VTEC won't work....
    Feb 2011
    Geelong
    EG4 B18CR
    any one??????
    Green block gangster Array
    twin GX160's
    code 6 is ECT and will stop you access VTEC
    http://www.ozhonda.com/forum/showthr...ics-Code-6-ECT
    code 20 is ELD and can be ignored or disabled in the ROM since your ECU is socketed.
    http://www.ozhonda.com/forum/showthr...82#post1209782
    code 23 is KS, you must have wired it incorrectly
    http://www.ozhonda.com/forum/showthr...3-Knock-Sensor
    in short no ECT no VTEC.
    Feb 2011
    Geelong
    EG4 B18CR
    ok i will check tomorrow morning thank you alot
    Feb 2011
    Geelong
    EG4 B18CR
    Thank you alot ECU-MAN everything is working, now i got a VTEC KICK IN YO!!!!!!!!!!!!!!!!! Thank you GODDDDDDDDDDDDDDD!!!!!!
    Nov 2009
    The Guy Next Door, Lol.
    KSWAPPED STi -R
    ECU MAN for president.
    Feb 2011
    Geelong
    EG4 B18CR
    the problem is ECT wire incorrectly location so i rewire this to correctly location now everything is work
    Mar 2008
    SYD-SG-JPN-MY
    welcome to the vtec club !
    PM me if you have b series performance parts!
    Feb 2011
    Geelong
    EG4 B18CR
    Quote Originally Posted by kcokla View Post
    love when the VTEC Kick in bro!!
    i still got a mate EG4 B16a2 conversion to do coming soon!!
    Jan 2013
    Brisbane, qld
    98 ek b18cr
    If the VTEC isn't connected/operating. It will set the limiter to roughly, if not exactly where vtec would usually kick in.
    Just so you know for future if anyone asks.
