Results 1 to 4 of 4
Hybrid View
    Ozhonda Trader Array
    Aug 2003
    Sydney.
    EGK24A
    Deatschwerks fuel pump
    Deatschwerks DW200 In-Tank Fuel Pump $140 incl gst
    Description
    Introducing the DW200 in-tank fuel pump which has all the all the benefits of the DW300 in a lower priced, lower flowing package.
    Flows 255 liters per hour (67 gallons per hour)
    In-tank application specific fitment
    Ethanol compatible
    3-year no-fault warranty
    Quiet and reliable turbine impeller
    Universal pump kit includes:
    2"x2" sock
    Electrical connector
    4" of fuel line
    Miscellaneous hardware
    Deatschwerks DW300 In-Tank Fuel Pump $215 incl gst
    Description
    DeatschWerks redesigned the DW300 to offer greater flow with no significant increase in current draw. The new DW300 pump flows 26% more at its peak and 20% more on average. The low amperage draw minimizes pump temperatures, maximizes pump life and reduces stress on OE wiring.
    The increases in flow were specifically engineered for high pressures (60-90psi), where forced induction applications need it the most. Conversely, fuel flow has been limited at low pressures (30-50psi) to minimize heat generation in return fuel systems. This dual zone approach results in a flatter flow curve, which maximizes both performance and reliability for supercharged or turbocharged applications.
    The DW Advantage
    Flows 340 liters per hour (90 gallons per hour)
    Ethanol compatible
    2"x2" sock
    4" of fuel line
    JDMyard Pty Ltd
    www.JDMyard.com
    •CRX• represent Array
    Nov 2003
    CRX+CBR250RR
    how do these compare to say walbro and bosch?
    Jul 2012
    Busselton, WA
    DECF28R & JB627
    Quote Originally Posted by Snoop_gee View Post
    Why don't you try one and get back to us.
    SSpamily
    Jun 2005
    syd
    560hp
    I've had the DW300
    perfectly fine.
