Currently have a log manifold, but have noticed that most setups are usong the rams horn type... looks like they position the turbo further down, will need to rethink that
The better style manifold has equal runners and support the weight of the turbo without cracking.
The flow on the log is not good as the ram.
Definitely look into it further man.
Originally Posted by alexzachary88
Dandenong north in vic
reason i asked is the radiator was made by these guys xcellent service and product.
Have some time on Saturday, will be putting in a 4 piece brace kit and then see if I have time to swap in the new speedo drive and cluster i got off you
Actually my list of things to do before I start the turbo install are:
New iacv
Get vtec working
Install brace kit
New discs and pads
Tidy up the engine wiring - is still a bit rough after the engine swap
Replace/alter the throttle cable as it's a bit sticky
