Page 2 of 2 FirstFirst 12
Results 13 to 18 of 18
    You're probably right... maybe the short shifter has caused damage to the gearbox =(
    Nov 2010
    Some where in the world
    b18c2+T Ej8
    I would check bushing too. the one on the gearbox.
    what i would do before taking the gearbox out is
    there is a pin in there take it out, get yourself a screw driver slide it in their and try to shift. if it's hard to shift, take out the gearbox and inspect it.
    Thanks hmetro... i'll try this out later!
  4. #16
    So it only just started doing it? Anyone tamper with the shifter recently?
    W.P. 1.10
  5. #17
    Nov 2009
    The Guy Next Door, Lol.
    KSWAPPED STi -R
    You dont have to remove bitch pin,
    Remove the change change rod on other side to test. Slide it back and foward to check.
  6. #18
    Update: Turns out the problem was with the shift gear linkage. 1 mechanic said to change the whole gearbox.
    Lucky I sought another opinion... he made some adjustments to the linkage for me and it's all good now!
    Thanks for all your help guys.
