Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 26
  1. #13
    Jan 2005
    Toronto, Ontario
    Corolla Spec S
    best in market
    peteju captures, like us on facebook..
  2. #14
    Feb 2011
    Geelong
    EG4 B18CR
    Quote Originally Posted by stndrd View Post
    Rocket Motorsport M22X is a nice camshaft for B18C7
    Like josh said M22x cam are good for B18c7 at the moment
    but i would go M22x or Skunk pro1 with RDX Injector and fuel regulator that would pull 140kw
  3. #15
    Thanks. Where can I purchase the m22s?
    EG
  4. #16
    Jul 2012
    Busselton, WA
    DECF28R & JB627
    The who recommends them, sells them.
    Best in market atm
    SSpamily
  5. #17
    Feb 2011
    Geelong
    EG4 B18CR
    Quote Originally Posted by infurNOS View Post
    PM stndrd Sleeping Performance & Mechanical Repairs supply them
    here some pic of Rocket Motorsports work
    Rocket Motorsports SL Springs and Retainers with Supertech Flat Faced Valves for B16/GSR. 11,000 rpm capabilities when combined with smooth revving RM cams
  6. #18
    Thanks for the info. Would I need to upgrade my springs? Or injectors?
    EG
  7. #19
    May 2004
    Hurstville
    jazz
    only needs valve springs + adj cam gear +tuneable ECU + spot on dial in for TODA B. works ok on stock b18c7 comp ratio imho. but i think the Toda A2 will be better for the low end and more noticable vtak crossover.
    Toda B pull smoothly 5krpm to 8.5krpm [or 9krpm if you dont mind running std injector @ 100% duty]
    ok ish low end, but will be a little tricky in car park with metal clutch in my case.
    Last edited by gambate; 28-09-2014 at 07:00 PM. Reason: +adj cam gear for dial in cam
  8. #20
    Feb 2011
    Geelong
    EG4 B18CR
    Yes need valve springs, adj cam gear, fuel regulator, RDX 410cc injectors
    better of speak to josh he will tell you what you need to do but he will re-opening at 10am 03.10.2014 due to race commitments both at Winton & Wakefield.
  9. #21
    What about buddy club spec 3 PLUS camshafts? Similar upgrades needed?
    EG
  10. #22
    Sep 2011
    forever waiting
    no weetek civic
    ask Super-DA9, iirc hes running those. if not the plus maybe just the spec 3s.
    SSpamily
    hehe
  11. #23
    Quote Originally Posted by carayan View Post
    I think it is the spec 3s because I may have sold him them lol
    EG
  12. #24
    Jul 2012
    Busselton, WA
    DECF28R & JB627
    I'm running Toda. can't go wrong.
    SSpamily
