Page 2 of 6 FirstFirst 12345 ... LastLast
Results 13 to 24 of 72
  1. #13
    Quote Originally Posted by lilthug View Post
    u got specs of your alignment?
    How will I find out the specs?
  2. #14
    Quote Originally Posted by ibbyDC2R View Post
    How exactly , do YOU think you can find your cars alignment specs ?
    Mate pls
    If your tyres are too far worn - grab new tyres ( either in a pair or whole set if there is wearing all thru) and get a full proper alignment front and rear. This will give you your spec to analyze and adjust to OEM specs.
  3. #15
ID:	27574 got two new front tires already, but I just wanted to fix the cambers so I don't have to change them too early coz of the inside wear, Bridgestone potenzas re002 195/55 15
  4. #16
    You can't adjust the stock cambers once there out of place they got be changed
  5. #17
    Dec 2011
    Sydney
    EK CIVIC
    If the car is stock height and running more than 1.5 degrees camber then the upper arm bushings have failed or if camber is around 1 degree the alignment (toe setting) is not right.
    Rather than guess, take the car to a suspension specialist and have it inspected and alignment checked with a report.
    OHSC
  6. #18
    When Bob Jane did the alignment they spotted it out and said my cambers are gone they couldn't align it this was last year I didn't bother aligning it this year
  7. #19
    Dec 2011
    Sydney
    EK CIVIC
    Look man, i'm just trying to help you (as are the other guys), but if you are just going to believe what a tyre shop told you a year ago then enjoy your tyre wear. And if someone told you that "your cambers are gone" you should find a new mechanic
    OHSC
  8. #20
    Oct 2004
    www.alibaba.com
    porsche boxster
    how much are new cambers
  9. #21
    Hardrace from JdmYARD $240
  10. #22
    Oct 2004
    www.alibaba.com
    porsche boxster
    Ok thanks
    don't like hardrace though coz they made in taiwan
  11. #23
    Apparently the skunk2 cambers people had problems with them
  12. #24
    Oct 2004
    www.alibaba.com
    porsche boxster
    Yeah it was a design flaw
