I have all the things I need 2 run the hose I just need 2 find out how to run it .... All so if the valve cover breather isn't closed off will it effect the vacuum or not ???
Blocking the valve cover will prob make it explode or crack....it needs to vent, either to catch can or use a babi filter
I explained how to run ur wastegate line...
U can also take a vacum source for it from the turbo housing/intercooler pipe right next to turbo...
Maybe post some pics of ur setup
Can't put pics up as I'm on my phone .... But it is the same as a greddy kit has a turbosmart 38gate and after market fpr I do have a catch can that I want to put in and some other small things all so has a greddy boost sensor running of a greddy ultimat piggy back ecu if that helps .... The pcv is still in but can be removed ... But I have run my vacuume line of the fpr hose and put a T in the line 2 run the bov but seems like it's not getting any vacuume as when I release the throttle nothing happens I have all so run it to the gate and dose the same thing get nothing at all
