Results 1 to 11 of 11
    Mar 2013
    Perth NoR
    S2k + CBX250
    [S2k] VC oil leak
    My s2000 has an oil leak somewhere on top of the Valve Cover.
    My guess is its the Washer Seals that hold down the VC.
    but I would like more opinions.
    I notice oil (mist and a very very small pool) in the spark plug area, under the black cover but not in the Spark Plug wells.
    also notice a mist around some of the Washer seals. i pulled them off cleaned it up and applied honda bond. yet the leak continues.
    any other ideas? spark plug seals? i wouldnt of thought it was as there isnt oil stuck to the coil pack or inside the well does not feel oily either, visually it doesnt look like there is a pool of oil in there and there is no misfiring.
    Dec 2008
    835 Beaufort St
    hondie 2000
    have u replaced the seals under the rocket cover
    hehe.
    PHC
    Mar 2013
    Perth NoR
    S2k + CBX250
    I have replaced the Spark plug tube seals, the washer ring seals and the VC gasket itself + the PCV O ring.
    very annoying for it to leak with fresh seals, unless maybe i damaged the VC washer seals
    Dec 2008
    835 Beaufort St
    hondie 2000
    Quote Originally Posted by Baby Face View Post
    maybe it needs to be gooed up a bit before it'll seal properly
    hehe.
    PHC
    Oct 2004
    www.alibaba.com
    porsche boxster
    is the rocket cover warped?
    Nov 2009
    The Guy Next Door, Lol.
    KSWAPPED STi -R
    Did u clean the mating surface when installing new seals?
    Mar 2013
    Perth NoR
    S2k + CBX250
    yeh i did sprayed degreaser to a rag and rubbed the surfaces then applied honda bond HT to the seals and waited a few minutes then tightened them down, thinking i might take it to honda and tell them to sort it out.
    the cover shouldnt be warped, but the leak isnt on the bottom of the VC its the top.
    Shouldn't bought a s2000
    Oct 2011
    16 Wilkins St E Annerley
    Toyota Soarer
    Quote Originally Posted by TrapLord_B20b View Post
    I told him to buy polo he didn't listen
    Mar 2013
    Perth NoR
    S2k + CBX250
    put new washers on, still got a leak from somewhere i think, just where.... gonna clean up and try again.
