jdm b18c swap into ek help. i hav a jdm b18c with a 4pin/wire alternator plug which is different to my ek4 engine loom alternator plug which is a 3 pin/wire plug. can i run the ek4 altenertaor which is a 3 pin/wire on the jdm b18c without it pulling an engine light due to it missing the 4th wire which i beleive is the ELD (Electrical Load Detector) wire. ill b running it on the jdm p73 ecu and not sure if the ecu will search for eld and may pop a check engine light which i dont want.
