Results 1 to 11 of 11
    d cluster flashing
    Hey guys, 02 dc5 base model auto 118xxx kms serviced a month ago
    anyone located in sydney who can help with scanning for error codes?
    The 'd' on my cluster started flashing I did some research but couldn't find much
    other than something to do with the trans.
    Anyone had any experience with this?
    Cheers.
    Try Hanny performance on 97255115
    Cheers I'll give em a ring when im free!
    Jun 2012
    Perth
    CD5 & GE6
    http://forums.clubrsx.com/showthread.php?t=709422
    When looking for solutions for your teg
    search RSX as that's Americas equivalent
    www.OzAccord.net/forum
    Quote Originally Posted by Jasemas View Post
    Thanks for that. I'll order the part now.
    What does the sensor actually do?
    Jun 2012
    Perth
    CD5 & GE6
    Dude don't throw parts at it like that
    First try and diagnose what's wrong with the TCU - transmission control unit
    The D light flashing is trying to tell you something
    Google Honda-Tech/manuals and try to find the workshop manual for your RSX it'll go through the stepby step procedure of what's wrong
    Jun 2012
    Perth
    CD5 & GE6
    Quote Originally Posted by BishaiR View Post
    http://forums.clubrsx.com/showthread.php?t=673881
    Cheers for the help, bought the bluetooth obd scanner from ebay, pulled the code p0845 which is the 3rd clutch transmission fluid pressure switch. Thanks for all the help. I'll go out and find the part today
    Jun 2012
    Perth
    CD5 & GE6
    Check the connections on the transmission and make sure the wiring is not loose or gunked up with oil
    Yeah, going to do it tomorrow, peter warren want 120 bucks for it and need to order it.
    I appreciate your time!
    All fixed cheers guys, it was the 3rd clutch pressure switch. Finally after 3 weeks it came in from japan. Switched it, no more error code and gear actually shifts slightly better.
