Page 1 of 2 12 LastLast
Results 1 to 12 of 15
    Accord Euro Acceleration Vibration - Clutch
    Hi guys,
    I have an 05 Euro with 170,000kms. I noticed at about 120,000kms slight vibration under acceleration which I put down to the front driveshafts. I didn't bother doing anything about it, and my girlfriend has been using the car since.
    I drove it recently and noticed the clutch didn't feel right. I thought it may be the fact that I drive a different car now and I wasn't used to it, although I do know she rides the clutch way too much.
    So I booked it in today and got the front driveshafts replaced with rebuilt ones. Not vibrating nearly as badly but at high speeds 80km/h + you can feel some vibration in 3rd/4th/5th/6th gears when accelerating hard.
    Mechanic has advised the clutch is the issue. I've been told a clutch costs $800 + labour approx $700, so it's $1500. Does not include replacement flywheel. Does this sound right?
    Is there any urgency to replace the clutch? It doesn't seem to be slipping. Just doesn't feel quite right when taking off from standstill and obviously the car is vibrating at higher speeds. Mechanic advised it's better to replace it as when it goes it could take the flywheel with it. Just after some opinions?
    Many Thanks.
    Oct 2010
    Melb
    '03 Euro [CL9]
    Dunno much about the issue but the cost for clutch replacement is excessive.
    2003 CL9 5AT *ECU REFLASHED*
    Aug 2008
    WA
    EP3R
    sounds excessive that quote... not much of help on your current issue, but IF and when you do get the clutch replaced, might want to change the thrust bearing too?
    Never argue with idiots, they bring you down to their level and beat you with experience.
    Jun 2012
    Perth
    CD5 & GE6
    Quote Originally Posted by soongster View Post
    And the rear main seal hehe
    You've gone through more accords than I changed underwear this month! - Sugz
    www.OzAccord.net/forum
    Aug 2006
    Sydney
    06 Euro luxury manual
    Quote Originally Posted by adamc11 View Post
    Hi guys,
    Many Thanks.
    Labour cost sounds about right.It's a big job.Have to drop subframe etc.=pain in the ass job.Get an Exedy stage 1 heavy duty clutch.While you're at it get a lightened flywheel.
    keep us update, same issue with me car
    I must admit the vibration does seem unusual to be coming from the clutch, i'd be pretty dissapointed if I was told it was the clutch and it didn't end up fixing the issue.
    Once the clutch is clamped onto the flywheel there shouldn't be any issues unless the actual clutch plate was bent which I doubt. The flywheel could be unbalanced possibly, but you would have to take a fair bit of material off it (in certain areas, as generally a clutch wears the flywheel constantly in the same spot apart from areas that may have received too much heat).
  8. #8
    Jun 2008
    Qld
    CL9 Euro Sport
    $800 is abit much for a clutch... replacement clutch or performance one?
    The vibration is from cv's, just did mine and now running smooth.
  9. #9
    Quote Originally Posted by soopaman View Post
    may i ask what is CV? how much did it cost you?
  10. #10
    Jun 2012
    Perth
    CD5 & GE6
    CV - constant velocity joint AKA driveshaft
    Connects your transmission to the wheels so your car can GO GO GO
  11. #11
    Jun 2008
    Qld
    CL9 Euro Sport
    what he said, i got some aftermarket ones $300 delivered duno if thats good or bad, and my brother and I just diy at home
  12. #12
    Sep 2011
    Victoria
    VTiR/CL9
    Ill sell you my exedy HD clutch(pink box) for $600 brand new
