What to do to install dc2r or em1 stock catback onto ej8
Are the cat backs for dc2r or em1 bigger than ej8?
Was thinking of putting one of these on an ej8 to have some better breathing but still retain as much quietness as possible
Thoughts??
Audm dc2r exhaust is 57mm (2.25") O.D stainless b pipe same as jdm, but the flange to the cat is 48mm O.D. It only tapers down for about a 3cm length at the flange because of the small diameter audm cat converter.
The axle back section is 54mm (2"), all mandrel bends, not sure if jdm is the same axle back.
mocchi and rc_ : i know em1 has an id of 50mm, is this the same for dc2r? or is dc2r for sure bigger?
Depends which dc2r exhaust you are talking about. Look at the link that exquisit posted.
As I said audm catback has a diameter reduction at the flange for the cat for about 3cm. If you cut that off then it is 57mm OD all the way to the rear axle flange then 54mm OD for the axle back. I haven't measured the wall thickness of pipe, but 1.6mm is pretty standard. I have measured the audm header collector pipe thickness and it is more like 1mm wall thickness. I will be cutting one soon so will be able to clarify.
Also it is all mandrel bends not press bent.
Is the Em1 exhaust press bent? If so that 50mm ID that you are talking about will be less at each bend. Where is the 50mm measured?
