.. Rt ddjsjsjz
hnggggggg
and to your query,any bseries with turbo kit would be fine looking at between 150-200 kw atw depending on turbo used
don't need turbo for such a light chassis k20a!
Even a B18C7 would rip in this chassis because it's so light and it's almost a straight drop in. run a OBD0-1 conversion harness, rewire vtec solenoid wire and use the B18C dizzy with a dizzy conversion harness. If you choose to run the B18C7 box you'll need to run a hydraulic to cable salve cylinder converter, hasport makes these.
OEM parts whore
Originally Posted by grifty Even a B18C7 would rip in this chassis because it's so light and it's almost a straight drop in. run a OBD0-1 conversion harness, rewire vtec solenoid wire and use the B18C dizzy with a dizzy conversion harness. If you choose to run the B18C7 box you'll need to run a hydraulic to cable salve cylinder converter, hasport makes these. yea hydraulic box would be biggest issue i rkn should be better option though
S P A M | W O R K S With our special rotational tires, it will allow you to drive very fast. - JK Tyre
Bau got banned for that highly insensitive comment Anyway great build best of luck OP
Originally Posted by bennjamin Bau got banned for that highly insensitive comment Anyway great build best of luck OP It was a request. Some might try to get the sympathy vote to get extra help. I believe ive actually helped the OP by bringing more attention to this thread than usual. No neec to thank me
SSpamily
Originally Posted by cbauto It was a request. Some might try to get the sympathy vote to get extra help. I believe ive actually helped the OP by bringing more attention to this thread than usual. No neec to thank me Thank
Users I've upset: EKVTIR-T | Renaissance_x | Integra-GSi | Stevil | vteckiller | dyln_bxtr | zedries | joyride | eren | Brian FD2R | AusS2000 | amant02 - II | CRXDEL501 | Indie | UiK | mnc | neut
Originally Posted by cbauto It was a request. Some might try to get the sympathy vote to get extra help. I believe ive actually helped the OP by bringing more attention to this thread than usual. No neec to thank me You would of helped him more by answering his questions.
that would be too easy. Originally Posted by rossirider You would of helped him more by answering his questions.
Originally Posted by rossirider You would of helped him more by answering his questions. That's only short term help I think cbauto way was helping long term
