Results 1 to 7 of 7
    Help!! Auto ek civic won't/can't shift into park, can't take key out of barrell
    As per title
    Missus was driving home then complained it wouldn't shift into park
    Checked fuses under the dash and brake light works
    Any ideas as to why it won't shift into park?
    Annoying as i can't take the key out of ignition barrel!
    Any way to bypass this also?
    Thanks in advance
    Sep 2003
    datsun 200b
    Not sure with auto ek's if they have the shift release hole where you insert the key near the shifter
    If you can, shove another key into it and see if you can put it into park, I have a feeling the locking mechanism in the shifter has taken a dump
    VTEC+Turbo=dirty underpants
    Mar 2014
    EK BRITTANY
    The key wont come out of the barrel if it is left in N or any other gears. Do you have a spare set of keys for it? if so try putting a key into the shift lock release slot and try and place it into park as it could have locked itself during another gear. if not it could be a bad sensor on the foot brake or some broken connection, try sliding the shifter around. check the actual cable leading to the trans and see if has popped out or has changed position under the car
    Yea tried the shift lock but I think that only works when stuck in park
    I'll have a look under the car later, I'll check under the shifter first now
    Green block gangster Array
    twin GX160's
    If the shift cable is OK and the shift selector cannot be faulted then your problem may reside in the trans.
    There is a cover that holds the cable to the trans, undo it and manually put the car in park by working the selector arm. If it will not select Park then the trans needs repairs.
    Jan 2012
    Glenwood
    Ek civic 97
    +1
    the pin that holds it in park must be stuck on the gear
    Same same but different
    twin GX160's
    If that where the case the car would be un drivable, car would not roll, not to say there isn't a fault with the park lock arm mech or selector shaft.
