read that thread..
From memory I used a ED crx inner joint. It worked fine for years. Technically it is a different joint, the EF8 has rollers in the inner joint where as ED does not - but still works fine. (this is all from memory of 8 years back).
Inner joints are easy to swap (but messy to fix) - outter joint can be easy.. but I recently had an issue with an accord shaft that didnt want the outer joint to pop off.
Thank you so much for this info you've shared! Greatly appreciated!
