Results 1 to 3 of 3
    Aug 2003
    Canb-Melb-Syd
    Long history
    New flywheel pivot bearing loose. - F22
    Hi all,
    I am replacing my clutch and flywheel in an accord with an F22.
    I tapped out the flywheel bearing of the OLD flywheel that which is made in USA.
    When I put the bearing in the NEW made in china flywheel it is very loose. It just falls in with no resistance at all and a slight gap as pictured - so it can spin freely. The clutch tool I have fits snug on the bearing - so pulling the bearing apart wider would result in a poor fit I presume too.
    Is this flywheel bearing needed? I would say so because the gearbox shaft that goes through the clutch would run on the bearing right? So having a loose tolerance would be bad?
    Aug 2003
    Canb-Melb-Syd
    Long history
    from what i hear, that bearing is meant to sit snug. So I just ended up getting the old flywheel machined.
    Oct 2006
    Melb
    P1.5 460F/350R
    nice met
    S P A M | W O R K S
