Can faulty temp gauge needles be fixed/repaired in anyway? Or normally people just swap out their entire cluster for a working one In this situation... Ed6 civic
i would like to know this aswell. my EK temp gauge is flicking up n down when ever im in carparks and stuff. but its not really getting hot
Sure it's not the temo gauge sensor on the side of the block thats gone haywire?
You've gone through more accords than I changed underwear this month! - Sugz www.OzAccord.net/forum
ok if it wasn't the sensor on the side of the block... then after can the needle be fixed or prob gotta swap out whole cluster with another...
You can change just the temp gauge in the cluster, the cluster is modular. You will have to change the fuel gauge as well
You have a PM
fuark that ozhonda watermark. ECU man nose. but yes changing the modulator is the easiest way but if you can source another for the same price. may aswell
Oh,you only know honda? NEED SUPPORT? I don't drive a honda
