G'day ladies and gents
I was under my car today (I work with cars as my day job) and was wiggling the shifter rods
I moved the rod with the uni joint on it and the joint itself is firm and tight
I then continued to head towards the part where the spring pin (aka bish pin),it was loose side to side and you can see that the hole where you insert the pin is loose, the hole on the selector shaft that's sticking out of the gearbox is larger in diameter due to it being worn out
What can I do to fix this?try a new spring pin?
Sorry if I don't make any sense, typing this as I'm half asleep!
Kenny
