Results 1 to 8 of 8
Thread: KTuner - 07 CL9
    Newcomer Array
    Apr 2005
    Sydney
    CL9
    KTuner - 07 CL9
    Quickie, will a KTuner work with 2007 CL9 ECU? or is a 07 TSX ECU required?
    Cheers,
    an!mal
    Green block gangster Array
    May 2004
    twin GX160's
    I'm pretty sure they are using the 05-06 Integra ECU's
    Oct 2010
    Melb
    '03 Euro [CL9]
    Quote Originally Posted by ECU-MAN View Post
    No. You're probably thinking kpro
    Ktuner does not use a honda accord euro ecu (matsushita/panasonic made, 512kb internal memory)
    Ktuner does not use a 07 to 08 Acura tsx ecu (Kelhin made, canbus enabled, 2mb internal memory)
    Ktuner uses a 7th gen wide body accord or 2nd gen crv Ecu. (Kelhin made, No canbus, 1mb internal memory)
    2003 CL9 5AT *ECU REFLASHED*
    Ktuner works without a TSX ECU. BUT!!! You lose your functions. No VSA and no Cruise Control
    Oct 2010
    Melb
    '03 Euro [CL9]
    Quote Originally Posted by Honda_FD View Post
    and instead you're using a CRV/widebody accord ecu. still a new replacement ecu, and then you chip it with the ktuner chip
    Newcomer Array
    Apr 2005
    Sydney
    CL9
    So if you buy KTuner you are supplied a modified ECU with their chip on it?
    http://ktuner.com/0406tsx/
    Are there any other oprtions without getting a TSX ECU?
    I am not too fussed about CC & VSA.
    Cheers,
    an!mal
    Oct 2010
    Melb
    '03 Euro [CL9]
    Quote Originally Posted by an!mal View Post
    Cheers,
    an!mal
    For a bit more extra you get both ecu and the chip I think.
    As to other options... if you are looking at custom *dyno tuning* it's pretty much btween flash pro and ktuner.
    A third method is you get a ktuner compatible ecu. Go to a ktuner dealer. The put their chip in, put in the tune then take the chip off.
    But that way you don't have any Control over the tune yourself
  8. #8
    Cant get a custom tune with stock ecu. You can look into Haltech?
    Not much out there in terms of ecus for Cl9s. Theres another solution, Theres a guy in Melbourne that Reflashes stock ECU's.
    A LOT of people have done it and have never read a bad review for It/Him.
    Im actually doing mine this Satuday. A guy took me for a drive in his Euro that has this flash and it pulls so much harder.
    Im really excited about it.
    http://"https://sites.google.com/sit...reflash/faq-s"
    From the stock map, the reflash changes:
    Ignition timing
    Fuel map
    VTEC switch over point (lowered to 4.6-5k rpm depending on throttle)
    Cam advance
    Throttle/Drive by wire mapping (no more lag)
    Redline (increased to 7600RPM)
