Results 1 to 11 of 11
    Do CRX B16 mounts interchangeable with EK?
    As EK4 mounts are hard to find atm, are CRX (Del Sol) B series mounts useable on a EK1? Will it all line up or is it the same story as the EG/DC engine mounts? Cheers in advance.
    Using Tapatalk
    Jul 2012
    Busselton, WA
    DECF28R & JB627
    Quote Originally Posted by DRIFTMONKIEZ View Post
    Sort of
    SSpamily
    Sort of? T bracket and all?
    Using Tapatalk
    Jul 2012
    Busselton, WA
    DECF28R & JB627
    Depends
    SSpamily
    lol bored prick
    t bracket - just go buy new one from honda or jdmyard
    jdmyard rapes the butt with prices lmao, was just wondering if they fit up before I make the last option to go brand new.
    Using Tapatalk
    Oct 2004
    1998 EK civic
    From memory, crx del sol use eg mounts which aren't the same as ek mounts.
    Just get hardrace or innovative mounts
    Aug 2003
    Canb-Melb-Syd
    Long history
    check part numbers on oemacuraparts.com
    Short answer NO.
    Long answer is yes , the REAR and DRIVERS SIDE mounts (rubber enclosed) should be compatible between the eg and ek.
    REAR T bracket needs to be off a ek4 / ek9
    Passenger side mount needs to be a EK item
    Drivers side is different
    Rear is compatible
    Quote Originally Posted by dorikin View Post
    Rear is compatible
    You are exactly right. Thinking of something else sorry team.
