Motul MoCOOL radiator fluid was developed for use in cooling systems under racing conditions to decrease engine operating temperature by up to 30 degrees F. MOTUL MoCOOL is a concentrated cooling fluid that may be mixed with distilled water for immediate use as a coolant, but can also be mixed with most existing coolants. It improves thermal exchange and engine cooling system efficiency. Recommended for magnesium, cast iron, aluminium alloys, brass, copper and bronze systems protection against corrosion.
WHAT IS IT?
Top engine cooling additive used to reduce engine temperature by 15°C (30°F) via outstanding thermal exchange in a concentrated cooling fluid, with anti-corrosion.
WHAT CAN I USE IT ON?
Any cooling system of bikes, cars, ATVs... when overheating is observed or in racing conditions to decrease engine operating temperature.
Especially handy with supercharger systems utilizing water to air. No coolant is needed, MoCOOL can be run straight with demineralized water.
HOW DOES IT WORK?
MoCOOL Cooling Fluid lowers surface tension, making more contact to allow for thermal heat dispersion. MoCOOL is an additive. You mix it (20:1) with distilled water for best results, but you can also mix it with most coolants. MoCOOL essentially works by making the little air bubbles that form in the cooling system smaller resulting in better heat transfer. It also contains additives that help to reduce corrosion that would otherwise come from running straight distilled water.
BEST USED?
With no coolants. Just straight MoCOOL mixed with demineralized water. Do NOT use MoCOOL with straight water.
Attention:
Some racing regulation do not allow anything else than pure water, if in any doubt, check with race official before use.
MoCOOL does not provide any antifreeze protection.
MIX with demineralized water at 5% (20:1)
Can be mix with most coolants monoethylenglycol based.
WHERE TO BUY: Motul Australia - Dealer Locator
Looking for the right oil for your car? Easy! Go to www.findmyoil.com.au*
*Findmyoil.com.au is for OEM recommendations only. For modified vehicles, consult your tuner or contact Motul.
Stay connected with
- Motul Australia Cars Facebook Page
- Motul Australia Website
- Motul on YouTube
Were here to help!
Cant find an authorised reseller near you? Any questions on queries? Let the Motul team know. Send us a PM!
If you have any questions about any of our products please feel free to get in contact with us.
