Hi all,
This arvo I was bleeding my rear brakes when my assistant pull ON the handbrake (she thought it should be on for safety). I wasn't aware this had happened when I decided to replace my rear pads while I had the wheels off. As I had to use a clamp to force the caliper piston back, would this have somehow damaged anything? I would've expected the calipers to be difficult if not impossible to remove with the handbrake on but they slid right off like normal.
I went through the bleeding procedure again after I found the handbrake on so I'm not too concerned from that perspective.
Haven't driven the car yet as I thought better to check here first.
