Hi guys I just bought a reverse camera from Supercheap and I have followed the correct procedure and wired it all up to work perfectly. The camera works how it should and turns on when the reverse gear is engaged and off when not etc.
The only issue is while I'm driving I notice that the screen flickers a little intermittently, does anyone know what is causing this? I have gone back over the connections again, nothing is loose or damaged so there should be any interference.
I have grounded the earth wire to a bolt on the chassis and I have wired the power source to the fuse of the electric windows. My car is an 05 Accord Euro. Would anyone know a solution to this? Could the monitor just be faulty? Thanks
