One problem with this mod that was noticeable - was the amount of vibration it introduces into the cabin. This almost made me reinstall the resonator.
One thing I highly recommend, is to insert some sort of heat proof rubber between the body and the filter box. This has made a massive difference to reducing the overall "noise" (bad noise, not good) and is far more stock sounding when at partial throttle - almost unnoticeable now.
Of course, you get into it - its better than stock.
Will try to to take a pic of my solution (workaround....) shortly. It was a leftover bicycle inner tube, wrapped up tight and jammed into the gap.
