This is hurting my head
Beeza
A swaybar is made to maintain ride comfort with progressive suspension...and a updated one enables more advanced handling in the corners. It also prevents "rolling" or "swaying".
Your can can does NOT handle better with stiff stuff coil overs mate. Get it through your head...stop being stubborn and spreading misleading "...my experience is this so I'm right"
The only way that proper coil overs make a car handle better (than a typical swaybar accompanied car) - are combined with semi or slick race tyres , ultra weight reduction and proper LSD as a minimum.
JUST "Coil overs" will make your road car handle worse on normal road tyres due to improper weight shift between tyres and the chassis. It will make you loose traction far quicker and have far less predictable handling.
But please , remove your swaybar a and run only stuff coil overs on the road. It's entirely up to you.
