Results 1 to 12 of 15
    Feb 2015
    2007 Euro Toure
    Sat Nav frozen CL9
    Hi guys,
    My Navigation screen froze on boot up today and is stuck on the Navigation Home screen, where usually it will get to the OK screen which then allows access to all the radio/ AC controls etc
    Anyone had this issue or know a fix?
    07 Accord euro tourer
    Aug 2008
    '96 Prelude VTi-R ATTS
    Tried turning it off and on again?
    Feb 2015
    2007 Euro Toure
    Well by turning off the car it restarts but still frozen on that home screen. I can't get access to the interface to manually turn it off and on if that's what u mean?
    Aug 2008
    Quote Originally Posted by malice View Post
    I was thinking more along the lines of pulling the fuse or disconnecting the battery. Still power going to it when you turn the ignition off.
    Feb 2015
    2007 Euro Toure
    It's just unfrozen. Weird.
    Next time it does that I'll try disconnect power like you said.
    Not sure what the issue was but hopefully it doesn't return.
    Thanks for the suggestions SafteyCar
    Feb 2015
    2007 Euro Toure
    The sat nav home screen has frozen for good now. It just loops through the home screen every 60 seconds.
    I have disconnected the neg on the battery and drained system juice and it hasn't fixed the problem.
    Not sure if anyone else has an idea? Or who i could take it to?
    Aug 2008
    Could remove it, pull the board(s) and check for bad solder joints and/or burnt out components. Other than that, not sure, possibly easier to get a replacement from the wreckers?
    Feb 2015
    2007 Euro Toure
    Quote Originally Posted by safetycar View Post
    Don't really like fiddling with boards, i'm not really tech minded like that. What about an auto elec?
    Nov 2016
    94 & 06 Accord
    Sorry if you have already tried this but have you tried pressing Map, Menu, and Cancel buttons for 5 seconds? (ignition on)
    Current: 2006 i-CTDi Tourer 1994 VTI Accord Wagon
    Feb 2015
    2007 Euro Toure
    Quote Originally Posted by Richard B View Post
    Yeah tried that but didn't do anything..
    I've noticed the problem seems to be with the DVD rom, when the screen works the DVD rom lights are on and when the screen is "looping" or frozen the DVD rom lights are all off.
    I've read it could be a temperature sensor inside the DVD rom. Which would make sense because the screen sporadically comes back on for a short turn every now and then
    Nov 2016
    94 & 06 Accord
    Can you remove the DVD or is it stuck?
    Feb 2015
    2007 Euro Toure
    I can remove the dvd. Makes no difference though
