Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 25
  1. #13
    Quote Originally Posted by Daveho1 View Post
    Maybe.. Dosnt explain the rain factor though.. TBH I think it's gonna be a vac or God aweful exhaust leak still don't know how te rain factors in though... Maybe a crack that's closed due to heat in the dry but the cool of the water keeps it open... Really need more info
    Maybe. Taken it to many mechanics and the engine has been tested all perfect. Will have a closer look at exhaust. Only happens in heavy rain or splash in big puddle and only after driving for about 10 mins. Cool Water is obviously reacting to a hot surface
    Sent from my SM-G360G using Tapatalk
  2. #14
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Tricky,probably need the car at hand to check things..hard to diagnose over the net.
  3. #15
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Updates?
  4. #16
    Dismiss if stupid. But I would try looking around where water could touch, especially from underneath. Maybe turn it only in your driveway and spray around with the hose. Kinda like vacuum leak diagnosis.
  5. #17
    Oct 2011
    16 Wilkins St E Annerley
    Toyota Soarer
    Have you tried driving in the dry?
    Users I've upset: EKVTIR-T | Renaissance_x | Integra-GSi | Stevil | vteckiller | dyln_bxtr | zedries | joyride | eren | Brian FD2R | AusS2000 | amant02 - II | CRXDEL501 | Indie | UiK | mnc | neut
  6. #18
    Aug 2012
    canberra
    DC2
    Quote Originally Posted by RenzokukenJ View Post
    What? Drive in the dry? Fuk up Renzo, no one can do that.
    Mate my bbk cost more than your Honda.
    -Amant02
  7. #19
    Sep 2006
    Out in Nature
    91 eg5 b16a
    If you're concerned about electrcal shorts/problems in the engine bay,u can go somewhere where it's really dark,at night,no moonlight and check for any electrical sparkage . running a couple of extra grounding leads is always good on an aging engine. File/sand the paint off where it cinnects to the chassis.
  8. #20
    looks like a common issue with catbacks?
  9. #21
    Ok guys I found the issue. Its the flex pipe in yhe stock headers. When it gets wet it loosens up and makes the cat back vibrate against the chassis. BTW my car doesnt stall just vibration and noise when theres heavy rain/standing water.
    Got the car on a hoist and sprayed the flex pipe which made subtle symptoms as driving on the road with heavy rain. Mechanic also got in the car and revd the engine whilst another pushed the catback against the chassis and replicated the vibration and noise.
    Catback has enough clearance however there is a slight dent in the chassis where the exhaust has been hit at the bottom.
    Solution: get aftermarket headers. Dan at Garage 91 in SA said most of the dc5/ep3 they service has headers already and one guy who put headers on which had springs opted to take them out and weld it.
    Hope that helps guys
    Highly recommend garage 91 for anyone in SA.
  10. #22
    Oct 2004
    www.alibaba.com
    porsche boxster
    Nice update and inpho
  11. #23
    Sep 2006
    Out in Nature
    91 eg5 b16a
    You must have got a bit excited when you said your car stalls?
    Because you now said your car didn't stall??
    Well done dtrang.
  12. #24
    nah just similar issue in the rain, vibration sounds fkd lol... looks like i need to get headers.
    such a common issue people have asked about on the net but no real answer so glad my mechanics found it.
