Hi all,
I recently picked up a 93 eg hatch with turbo mini me swap (d15b4 block with a d16z6 sohc head)
It has been back yarded together but has some good parts etc.
I have fixed a fair bit of wiring, vacume leaks etc but it still isnt running quite right. It is runing super rich with denso 440cc injectors (alot bigger than stock) kind of sounds like its missing? Or runing on 3 cylinders (i have pulled off each plug to check)
Could it just be due to the base tune? It hates cold start.
It has a hondata s300 vtec model, its all wired up as far as i can see, has any one on here done the mini me and turbo swap? I would love to see a swap in person to double check everything before i go to the tuners.
Located in ormeau, queensland
