Results 1 to 8 of 8
Hybrid View
    Nov 2005
    Sydney, NSW
    DC5R
    Help with F20C engine.
    Is it normal for an S2000 to burn through 4 litres of engine oil in 3000kms?
    My oil light came on today and I checked the sump and it's way below minimum safe level. I've had a look under the car to see if it was leaking oil but didn't find anything. I've heard vtec engines burn a little bit of oil as they operate but is the amount I've described normal?
    I've garaged the car and I'm going to get more oil tomorrow. I wanted to ask if there's anything else I should be checking to see if anything needs replacing.
    Thanks heaps guys.
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Are you sure you have lost 4L? Doesn't sound right. .unless there is a leak..
    When there's only a bit of oil on the bottom of the dipstick,my d16y4 takes about 1L.
    You always lose more in summer with the hotter temps.
    Nov 2005
    Sydney, NSW
    DC5R
    Quote Originally Posted by beeza View Post
    You were right, it wasn't 4L, I refilled the sump and it took 2L.
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Ah great,I would just keep an eye out for leaks..probably is just evaporation though.
    Aug 2009
    Front yard
    4WD 89 Concerto
    Most likely your valve guides are bad and it's burning a lot of oil. Well known problem on the S2000.
    OEM parts whore
    Oct 2009
    hehe
    hehe
    2lt per 3k kms is not normal
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Yeah for sure. .grifty sounds right. I Google it.. def worth checking blaze.
    Dec 2008
    835 Beaufort St
    hondie 2000
    dude that's not right. Get it looked at.
    I burn no oil, even with boost.
    hehe.
    PHC
