Fredoops explained to us that he replaced his cables with larger cables. He mentioned that he replaced the chassis to battery cable to 4 awg cable (nearly twice as thick (from 20mm2 to 35 mm2). There are 2 chassis to engine cable, one near the engine mount and one under the air box (harder to see and access). Fredoops changed the one close to the right engine mount.
Yeah after some time, some corrosion takes place and the resistance gets too high. You can buy an original cable from Honda (I'm sure it's not too expensive) or better still to replace with bigger cables especially if you have aftermarket accessories (head unit, subwoofer, etc...).
