Results 1 to 12 of 17
Hybrid View
    Changing Transmission Fluid Help DC5R
    I own a dc5r with 175,000 km. For the one year i have owned it the gear shifts have been very smooth and overall have felt very solid. However, the last month or so that is not the case. Gears are much harder to get into than previously and overall quality feels bad. Ive never tracked the car but i do drive the car in a spiritedly manner quite often. I am not sure when the transmission fluid was changed last so i am worried if i do change it i could loosen deposits that have settled into place etc. As for what oil/fluid to use i am not sure for my car. Ive done a lot of research but could not find a good reccomendation for my specific car. Would appreciate any knowledge and recommendations of what fluid/oil to use as i am a noob. Keep in mind the issues i have with the car at the moment and the fact that its a daily and is driven in hot conditions in summer. Thanks.
    Oct 2004
    www.alibaba.com
    porsche boxster
    Honda mtf mate,can't go wrong
    dont think i can buy that here mate.
    Quote Originally Posted by Tony99 View Post
    Run MTF06 ( oem honda stuff)
    Its not hard to drop the fluid , ask a local DIY guy on here to help
    from perth mate.
    Oct 2011
    16 Wilkins St E Annerley
    Toyota Soarer
    from perth mate.
    nice man
    go to dealership
    ask for oils
    go to mech
    ask to put in
    10/10
    would
    repair
    again
    Nov 2009
    The Guy Next Door, Lol.
    KSWAPPED STi -R
    75w90 gbok oil. If you idunno which oil to use is best to let a mechanic do it.
    Oct 2011
    Toyota Soarer
    75w80 is the one you use my friend
    Sent from my SM-G928I using Tapatalk
    Nov 2009
    KSWAPPED STi -R
    Buy any GL5 75w90
    or buy MTF
    if you want recommendations, i have used penrite pro gear, motul 300v and motul ff type 2 all with great success.
    Also the oil weight should be dependent on weather and conditions for us aussies its 75w90 GL 5 for most modern day cars.
    Hi Tony99, On the oil type to use you can go genuine oil which will definitely do the job, after market oils are good too - the grade of oil should be listed in the owners handbook if the car came with that. Other than that most of the retailers will have a look up chart where you can confirm the type of oil brand and grade is best. Bear in mind that you want to make sure you do see a listing for your specific model - assume the DC5R has a LSD factory fitted. I've used Castrol VMX 80 successfully in a LSD equiped fwd honda gearbox.
    The metal wearing parts (very very fine particle sizes) will drain out as you remove the old oil but make sure you give the drain plug a really good clean as these are magnetic at times and will hold small bits of debris to ensure that they don't cause premature wear in the 'box. Depending on the breather location on the gearbox you shouldn't really have any sediment/gunk in there unless the box has been submerged for some strange reason....
    With ambient temperature this is normally a concern at the extreme ends of the range - eg very negative Celsius and very high celsius, normal operating temperatures ranging from -5 to +45 you'll find the standard stuff works well. If you're operating at the top end of the temperature range consistently then more frequent oil changes would be a good preventative idea. In very extreme conditions you'd look to fit an oil cooler however these are more inclined to be needed in automatics under heavy load like towing applications.
    Quote Originally Posted by 1wht86teg View Post
    thank you for the reply. will definetly follow the advice.
