Results 1 to 10 of 10
    Jun 2017
    Geelong, Vic
    92 CRX delsol
    Question 92 delsol crx fuel pump fuse location?
    Hi guys keen to get into the car and get it running nicely so first thing i need to do is a comp and pressure test.
    Ive searched the net and ive checked the fuse boxes and i cant seem to find the fuel pump fuse location? it doesnt seem to be listed on the fuse box covers either?
    If someone could post a pic or something like that i would very much appreciate it. cheers
    Jun 2017
    Geelong, Vic
    92 CRX delsol
    Heres a few pics of the fuse boxes might help jog someones memory.
ID:	30110   Click image for larger version.
ID:	30111   Click image for larger version.
ID:	30112   Click image for larger version.
ID:	30113   Click image for larger version.
    Nov 2009
    The Guy Next Door, Lol.
    KSWAPPED STi -R
    Its built into the main relay fuse. Why you doing this? Car not starting? I think its common for this part to break. PM ECUMAN on here for cheap fix.
    Jun 2017
    Geelong, Vic
    92 CRX delsol
    So i can compression test the cylinders. So i may need to add and inline fuse i guess :/
    Aug 2009
    Front yard
    4WD 89 Concerto
    Are you sure the fuel pump itself is not dead?
    OEM parts whore
    Jun 2017
    Geelong, Vic
    92 CRX delsol
    the car runs, to do a compression test you need to disable the fuel system so it doesnt inject fuel, thus the reason im looking for a fuse..
    Nov 2009
    KSWAPPED STi -R
    Disconnect the fuel pump
    or Disconnect the injector pig tails.
    Just make sure all coilpacks are removed, worse case scenario no spark = no boom.
    Aug 2009
    Front yard
    4WD 89 Concerto
    Just disconnect the injectors
    OEM parts whore
    Jan 2012
    brisvegas
    G6E turbo
    Drain the petrol tank
    FFamily
    Green block gangster Array
    twin GX160's
    unplug the ECU
