I don't mind this system, but i didn't mind the two session system either, as far as i can see its basically the same as last year which worked fine. From what i understood, you can adjust the set-up if the conditions change from like wet to dry or vice versa, but apart from that, nothing.
As alonso said, in the end, it doesn't really matter as long as its an even playing field.
