1. wind the window down, and check it the rubber seal has any foriegn objects get caught in between. Clean it off.
2. If it is from the inside the door penel, u need to remove the door penel and do more investigation.. I havn't done it myself before. I guess Honda service people can check it out for u too.
My windows squeek, use silicone spray, does the job!
speaking of windows, my driver side window is scratched really bad..
Does anybody here know what causes this ?? is it common with you guys ???what needs to be changed ??? are there seals or something that goes inside the door trim to protect the window ???
I remember rubber seals peeling off over time, but this occured after the scratches
you can use silicone spray.. or a rubber care spray.
i'd prefer rubber care spray.
i find that rubber care works better.
plus that's what the workshop uses.
lol.
my driver side window is driving me nuts! i dont even pull the window down when there are girls in the car cuz of the squeak.
i've used silicon spray like the pic above but still sqeaks and seems to be bcause the rubber is rubbing against the window. this onli happens when goin down.
