Sorry i don't agree. Lifting off the throttle is altering the balance of the car via a transfer of weight off the rear wheels.......hence INDUCING oversteer as the rear loses traction.
but isnt oversteer the loss of traction in the rear wheels?
IMO no - since "understeer" is not necessarily "loss of traction" -
IMO both understeer and oversteer can be defined as the tendency for either the rear axle or front axle to loose balance with the opposite end and be guided by inertia to the widest point of a corner.
This could be via throttle control , loss of tracion , differential bias , crappy driving , excess speed or whatever...
yesh it is... its the physical car moving .. not somehitng u feel in the seat of your pants...
you might feel its gonna oversteer in the heat of the moment.. but your car has yet to oversteer..and corrections dont even need to be made.
you cant get the feeling from the dictionary
what happens when your car looses balance? it tippie toes and regains balance?
and i think the dictionary meaning is about drifting.... \
how do u get oversteer in rwd? you induce it with the throttle control...
how do u get oversteer in fwd? you induce it with the throttle control...
Many things im sure have to be considered/applied for "understeer or oversteer" to occur. Speed , traction , weight bias , brake bias , power , differential types , ground surface etc etc.
You can come into the apex of a corner too fast or be braking etc and understeer wide. No "induced power" there.
You can lift off mid corner -weight is transfered to the front axle and the rear will sometimes break traction OR you apply the handbrake OR there is lack of sufficinent grip - all brining the rear into "oversteer".
No "induced power" there either.
IMO Oversteer and understeer are NOT just "loss of traction" - they are from differential bias or wheel alignment etc too.
The front or rear axle AFAIK does not have to be loosing traction to be in "oversteer" or "understeer".
Can someone who 100% knows what they are talking about reply here ?
Remember this is all "IMO" ....
oversteer is over steer....
what happens when u lift off the throttle mid corner? u get over steer...
Most oversteer is throttle induced.. even in rear wheel drive
I agree, yes it is a type of oversteer. But its not the same as what we are talking about here. We are talking about the natural reaction by the car when its been taken to the edge. Not when it has been induced by lifting off the accelerator, touching the brakes, or any other means.
And when you mentioned about being able to induce lift-off oversteer with a 22mm rear sway bar, the sway bar will make it easier. But I can induce lift-off oversteer on my car which has no rear sway bar.
Lift-off oversteer is caused by the shift of the car weight moving when you suddenly back off the accelerator at high speeds. This causes the car to unbalance and oversteer is usually the result.
Personally I think understeer is when there is loss of traction at the front wheels, which causes your front to continue straight and run off your line through the corner. Oversteer is when the rear looses traction and causes the back end to run off the line through the corner.
Oversteer and lift off oversteer are two different things.
WOT oversteer and lift-off oversteer are to two different things. But they are both classified as oversteer and are a result of loss of traction of the rear wheels. Just like understeer is a result of loss of traction of the front wheels.
If you guys take a step back you will realise you are wrong and that u are arguing a frivolous point.
_________________________________________ FOR SALE: '98 EK CIVIC VTi-R
______________________________________________
that is exactly what i am saying...
its a mod slug fest
I cant believe they arent agreeing with
And all oversteer is throttle induced......!!!!
QUOTE!!! throttle induced.....
lift off(FWD) or accelerate (RWD)!!!!!
its a mod slug fest
remember you stated from under+oversteer must be from/via a loss of traction . And i said understeer/ovesteer IS NOT just throttle induced.
I want this discussion to keep going as it all is our opinons
That's what i'm trying to say........they are both cases of over oversteer however in one case it is induced as you back off the throttle and in the other case it is a direct inheritance of the cars suspension setup.
I'm not saying you're wrong Blitz.....i'm just saying one is induced intentionally by backing off the throttle.
