2 for the doors, so thats one per side.
The ceiling lights, you need 3. two at the front and one in the rear.
lifespan, im not too sure, mine have lasted for more than 2 years so far. before that i had different colour, lasted alsmot the same time, probably still be ok. I changed them bcoz.....well i wanted a different colour....hahaha
eBay would be best go for these, be cheaper than autobarn n supercheap.
if you wanted bright ones, like i did, i looked for SMD LEDs or Flux LEDS, they were bright as.
Ahh, righteo, so cheaper = lesser quality in this case i suppose.
2 years is hell fine.
I'll give the ebay ones ago and see how bright they are.
theyre not gonna be for any 'real' purpose lol, just to look nice when i unlock the car ^^
Yeah I've done my doors and plate lights with blue, looks funkai!
Cost about $2 each from hong kong ebay
So i had a look see before i got my bulbs to see how to remove and access the bulbs, but can anyone show me how to remove the door ones?
tried to pry it like the others with my tools, but feels like i might break it lol.
+ how do u change em if they're constantly on when the door opens?
for the door lights.. i just pryed it with a small flathead on the minigap in the middle of the plastic, cant remember on the top or bottom. and yes its always on.. although bit dangerous, i just plugged it in and out still works, hope that helps
yep, i go from top with a flathead screwy.
Just be careful the bulb might get a bit warm/hot when u go to take the bulb out. Dont want u to burn yourself etc.
Reccomend you to use a cloth when you take out the bulbs
WTB: NSW CL9 facelift front bumper in Graphite / Grey
awesome i'll give it a go once i feel better, this flu going around is INSANE
hey guys... just to let you know...
i was tryna change my vanity mirror lights on my 07' and i was using the info from here..
ordered 31mm fuse LEDs... turns out the euro uses 29mm..
should have really measured before i ordered them.. oh wells..
so yeah... it didnt fit... just a heads up
changed the parkers, door, maps and plate lights with LEDs... nice as.. ill put pics up later
For Sale:
95' Civic Sedan VTI 165,000ks
5zigen GN+ ( 17 x 7.5 +43 4 x 100) with tyres
07' CL9 Foglight covers Arctic Blue pm me!
Hey guys,
CU2 models with the blue led lights in the front and rear foot welds... does the White LED lights over power the blue light? This is with the door lights as i have noticed that the Honda Accessory lights arnt that bright to begin with...
BUMP
Hi Guys
Noob with all this stuff, so thought Id bump up this thread. I've been able to find heaps of info, but some of the links to buy leds for my 05 Accord are no longer working. I guess it is a matter of trial and hopefully you get a good set of lights.
I'm looking at getting Blue T10 - 5 SMD LEDs for the door
http://www.dealextreme.com/p/t10-1w-...-58297?item=30
and 31mm - 6 SMD LEDs for the map lights and cabin light at the back
http://www.dealextreme.com/p/31mm-1-...-51003?item=14
Will the Map Lights be bright enough and fit as well?
Also, I haven't tried opening up the Licence Plate lights, but what would be the best T10's for the plate lights so it is bright enough to see the plate.
Cheers
31mm for map lights wont fit flush!
For Sale:
