Noob crowd controller
Array
Civic rotor/disc question
Hi all,
Hope someone can help me with this. I read something interesting the other day on the net that eg and ek civics were produced with two different size discs. 90-03 civics were said to have either a 240mm disc or a 262mm disc (years 94-03). I have two questions: why would Honda vary the disc size on different models? and what size discs would a facelifted ek1 hatch have?
Would an extra 22mm make that much of a difference in stopping power?
Does anyone have any answers to this?
See a good post? Give it a PQ point.
Originally Posted by ludecrs
They have the depreciation re-sale value of a burnt out and multi-rolled Commodore.
disc size increased to accommodate a larger caliper... so once again disc has nothing to do with the extra stopping power... more about caliper piston being larger and hence more bite.
To the best of my knowledge EK1 had 10.3 inch rotor... ie 262mm.
Array
type one - always full of useful knowledge . Thanks .
Can anyone else confirm this?
yes ek1's have a 262mm front rotors
Array
Thanks for the confirmation .
Except that it is out and out wrong, simple physics will tell you that when the same amount of force (caliper clamping the pads) is applied with a greater lever (rotor diameter) it will generate greater torque (stopping power). Anyway, the initial limiting factor for braking force in any properly functioning car will be the tyre's grip on the road. The next concern becomes the brakes ability to absorb and dissipate the heat generated, the former is largely a function of the discs mass, the latter depends on the design, airflow, relative temperatures etc. But the simple answer is the bigger brakes will have greater braking capacity.
Now I'm no honda expert but a quick squiz on the wonderful DBA website yields this list;
PN - 473 (240mm x 21mm)
EG GL, GLi, VEi, Sedan, 11/91 - 94
1.3i 16V (EG33) 1994 - 95
1.4i 16V 3/4DR (EJ9) 1996 - 97
1.5i 16V / VTEC-E (EG43-EF85) 1991 - 95
1.5i Coupe 16V (EJ2) 1994 - 95
1.6i 16V / VTEC (EG53-EH95) ESi 1991 - 95
1.6i 16V 77kW (EJ6) - automatic 1996 - 97
DX/HX Coupe/Sedan (USA) 1993 - on
Del Sol, Wagovan (USA)
PN - 474 (262mm x 21mm)
EE9, EF, EG 1.6i VTEC VTi 11/91 - 95
EH1 4WD, EJ1 Coupe 1.6i
Coupe /Sedan EX/LX (USA) 1990 - 95
MA8 1.4i, MA9, MB1/4 12/94 - on
MB2, MB3, MB7/8/9, MC1 1997 - on
MC3 2.0TDi, EJ6/8
EK 3 Door
Hot Gem,
Top of this class! Of coarse a larger rotor will increase braking power, and all the other factors he lists.
