I assume that you will run 20 LEDs in series and 7 rows in parallel. Will you have enough voltage to light up 20 of them to the full brightness? Again my assumption is running 5mm round LEDs.
I am actually thinking of using the superflux led. As I can neatly lay them side by side.
Not sure that the outcome will be but I will give it a try. If not I will probly try the 10mm ones. I like your thinkig as not to put the cover on. Might even spray the board to red colour.
superflux led? where u can get that?
I run 5-6 LED in series depends on the length of that row with certain amount of resistor which is way enough for brake. I have sprayed the board in red and will put a thin red tinted plastic on top of that as well. Till working on as it is quite time consuming.
For interior lights like dashboard, we need a BRIGHTER one not those gay 5mm one which I used for my brake and ceiling light.
it is not hard to do it. just go dicksmith and get everything u need. Also web is your frd. =)
