hahah yeah it's Gallons.. i'd be talking to Georgie Bush Jr if you were paying more for 'gas' in seppo's-ville that 'down under'.. anyway that's another topic
Wired in the O2 sensor last night.. ended up getting IAT, TPS, CTS codes.. so I reverted wiring but kept the 'new' wiring.. got rid of those other codes but back to O2 heater Code..
Am goin now to go try another approach.. JDM v US v AUS wiring sux HAHAH..
Am going to re-wire the plug to the engine harness as 2 wires need to go off to 'other places' before they hit the ECU.. the other 2 wires stay wired directly to the ECU..
what a nightmare !! I just hope it works !!
I was equipped by Mugen
Array
Bede, we have Honda manuals here where i work covering your wiring problems.
Perhaps i could photocopy some pages ?
Honda resource for enthusiasts with all the latest news from Honda, downloads, media, photo albums, technical information and lots more!
Green block gangster
Array
the knock sensor is there to retard timming when your engine pings, fuel changes or what ever else could cause knocking. the factory knock sensor is average, the dudes in the states that bother with them use more sensitive ones. at the end of the day , run RON98 and dont bother with the knock sensor.
Array
Originally Posted by VT3C
Adam, do you have access to JDM EG6 or DelSol Wiring diagrams ?
Aussie is no good for me although Aussie EG5 VTi wiring would be handy as I only have USA-spec wiring diagrams ?!
We have manuals for every car out there pretty much but nothing after 2000 for Hondas that ive seen.
I did see a EG and EK manual.
What pages are you after ?
yeah I ALWAYS use 98RON.. but why am I only getting this code NOW ?? not before ? Like I said I cant hear/feel any knocking.. and from what I gather I should be able to hear it if it does it.
took her for a run to the shops last night and did an RSM Power-chart in 2nd gear and was the straightest power curve i've seen in my car and peak power was at 8040RPM.. and got all the way home without Knock sensor code showwing up.
I think i'll clean my plugs and then re-set my ECU again today and see how she goes..
I re-soldered up my old knock sensor and are going to try to put it back in and see what happens..
hmm I have the Haynes Manual with a red EG coupe on the front.. but it obviously covers LHD and only SOHC engines.
If you have one for AUSSIE VTi or JAP SiR-II or JAP CRX Del-Sol SiR-II.. maybe the pages on PGMFI, Engine Harness, Engine sensor wiring Diagrams and maybe P30 ECU pinouts ? Has to be EG/Del-Sol though as it has to be OBD1.. EK4 SiR's etc are OBD2a
I've had absolutelty NO LUCK finding these resources, but if you have them would be greatly appreciated.
Array
I will have a look soon.
I know one of them has B16A engines in it.
Seriously Bede
just disable the knock sensor, its overkill not requierd.
I dont even run one on the turbo B16.
I'll ship you a modified eprom and you can see for yourself.
shoot me an email, we can discuss where we left off
Originally Posted by ProECU
Seriously Bede
hahah yeah I think i'd rather that than ~$200 for a new Knock sensor.. You'll get to know me that I will always try to fix things first before I outsource
but yeah I think a disabled knock sensor will just make life easier.. Tax Return comes in soon, so we can sort out something
am writing u an email now..
Array
Bede, I got the Haynes Civic, CRV and Integra 96 - 00 manual. It covers DOHC VTEC engines.
hmm 96 and on is OBD2 but then most the other DOHC VTEC stuff that is not electrical related would be suitable.. like clutch etc.. but unfortunately the Haynes ones are LHD and USA-spec (emmissions).. so unfortunately a lot of differences in the electrics.. sigh.. JDM sucks yo !! haha
Thanks for that, will let you know..
