B engine Honda injectors are 240cc
H engine Honda injectors (h22) are 270cc
The question is thow on a B engine 240cc in almost EVERY mild modifications the stock injectors are 100% perfect for all Mild applications, hell even in a b20 vtec engine with Toda Spec A cam's stock 240cc injectors are more than enough fuel... So the question must be raised why do you want larger injectors.. bigger injectors DOES NOT = more power.
If anything more fuel... running a engine to rich, un tuned will decrease performance and use up more fuel per KM.. why would you do such a stupid thing ?
I strongly do not recommend upgrading to larger injectors unless there’s a reason why your engine needs more fuel, and if that’s the case you should be looking at 440cc or larger injectors along with a programmable ECU.
