What have you done to the car?
If it's stock have you tried resetting the ECU? If not take the ground wire off the battery for an hour and re hook it up. Should reset your settings and re adjust itself when you start driving.
If your car is stock... sounds like one of your sensors is playing up and causing the car to run "wrong" a programmable ecu won't fix this problem unless you replace all your sensors, along with a programmable ECU. The easiest way is to diagnose what’s wrong with your car replace the required sensors, which will result in everything returning to normal on your stock ECU, if your after performance gains, then look at a tuneable ECU.
All thats done is induction removed all piping from in the gaurd and run straight induction into airbox with K&N Pannel aswell as exhaust manifold back High flow cat, No
Engine light have replaced Map sensor checked Oxy sensor it is fine Error was showing map sensor.. I should try removing the earth so that it all resets...
Its a B18A1
