dont thinks its a sump leak cos that mean my driveway would be covered in oil. my mate said when i deck the car black smoke comes out when im changing gears.
Here is your problem - when you drive a car with the k's rolled back...you dont actually know that its becoz ur car has about 302,000km's . . . when it only reads 24,000.
Oh , BTW - if ur car is burning oil , then it would blow out WHITE smoke.
Blowing out black/dark smoke is normal under heavy load, as the engine runs richer up high and so pollutes abit more.
Oil could be leaking into somewhere...into other parts of your car - get a physical person to look at ur car ( IE a mechanic)
If your driveway is clean your head gasket (as suggested) is on the way out (already has a crack) or you are burning oil at a slow rate.
Is the smoke thick when you drive hard? Does it blow smoke when you drive normally? You sure it's black?
Wat kind of car is it?? my car does the same, only wen i push it hard n change gears! (only in vtec) Its because my car is running rich (I run the car rich for a reason)! i've had my mechanic look at the car and he said there is no oil leaks if there were oil leaks it would blow blue smoke! if u fine tune it, it shouldnt smoke!
what this about ben. i didnt roll my clock back.
my car has done 100k
its just a puff of that blue smoke the other boys where toking bout.
i spoke to my mechanic he said you will lose oil if youre given it a hard time. but i'll ask him about the head gasket? thanks boys
