Page 1 of 2 12 LastLast
Results 1 to 12 of 15
    Mar 2004
    Melbourne
    DC5S but not for long...
    "Rubbing" Sound SInce New 16s
    hi guys, i get a "rubbing sound" since i got new 16 inch wheels (upgrade 15) for an Ek4 hatch today...
    weird thing is, i ONLY get the sound when turning LEFT at high speeds (around 70KM Plus)
    I'm not so concerned cos my suspension is height adjustable, but is that theonly problem? car too low for the rims?
    and how come it doesnt do it when i take a hard RIGHT?
    for the responses
    Oct 2004
    Brisbaneville
    EG civic si (d16a8)
    coz more weight on right side of car "ie YOU" :S
    how much gap u got at the moment? also check your CV's although probly wouldn't be a "rubing sound" if CVs.
    could always just raise the right hand side of the car a bit more "not much"
    or just raise all corners
    Mar 2004
    Melbourne
    i think CVs make more of a "clicking/rattling" sound...
    and its too coincidental cos i just got the problem and the rims today
    ah well, i'll just jack it up a notch on the driver side tomrorow... i never thought about the "heavier thing"... now that i think about it, steering wheel, cluster, ME, probably causing the imbalance, cheers for that...
    Mar 2005
    Auckland, NZ
    DC2 Teggie, EK4 SIR
    check you offset, they offset is wrong on the rims for your car.. honda is 40-45 i think.. 35 is about a far out you want to go..
    TRAVDM Array
    May 2004
    BNE, Q
    Lots of Hondas
    i have the same thing. cept mine is at low speeds turnin left.
    all it is, is one wheel rubbing on the fender liner plastic plug.
    have a look under ur car man, what width r the 16s over the 15s? that could be also the problem.
    get under ur car and have a look man, look for something that looks like its been rubbing.
    oh wrd!
    Needs more time... Array
    Aug 2003
    Sydney
    Blog Entries
    12
    Like trav said.......its probably rubbing either your guard.....or the splash guard. Take the wheel off and look inside for 'rubbing' marks.
    Got a question? Check out the FAQ - http://www.ozhonda.com/go/faq
    Mar 2004
    Melbourne
    sigh... i upgraded from 15x6 to 16x6.5 so thats the reason i suppose : ( now i need to raise the height...
    do i need to take out the whole shock/spring to do it? or does the c-spanner and notches adjustment thingie do the job?
    u reckon its possible to just adjust dampening to STIFFER to avoid rubbing?>
  8. #8
    Noob crowd controller Array
    Sep 2004
    Civic
    Quote Originally Posted by **Ghost**
    I have the same problem Ghost but like egSi at much lower speeds. Wait until you get someone to ride in the back as well and you will hear it much more.
    Depending on the suspension I dont think you will need to remove it. Just use the c-spanner to adjust them a little higher. That is what I am planning on doing to mine when I get the time. Your other option is always to take the corners slower .
    See a good post? Give it a PQ point.
    Quote Originally Posted by ludecrs View Post
    They have the depreciation re-sale value of a burnt out and multi-rolled Commodore.
  9. #9
    Dec 2004
    West Sydney, NSW
    Integra VTi-R 98'
    get your gaurds rolled, (this will increase wheel space) inside the gaurd. that should fix it. either that or your rims are too wide.
  10. #10
    Mar 2004
    Melbourne
    couldnt i just raise my car? or adjust dampening?
  11. #11
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    depends on which part is rubbing. It si usually your rear wheels from experience.
    You can get the rear guards rolled and that should help, depnding on which part is rubbing (i.e the inner side) you could get spacers.
    Getting the outter guards rolled was like $80 each side from Aussie Tyres last time i asked. Or you could do it the cheap way and get and angle grinder to cut some off. (backyard job) Just rem to touch up the guards with paint if you cut it to stop it from rusting.
    Evo IX - THE FINAL EVOLUTION
  12. #12
    Oct 2004
    Jazz EVO IX
    btw... if you raise your car you'll prob loose your handling advantage (which is why i am sure you got 16's in the first place). Stiffer springs may not help as you shafts have a slight play in them 1cm or so and i am sure that is wat is making it only rub on one side. (had the same problem also) Changing mags with different offset can help also
