Aim: installation of short shift adapter to reduce shift throw by 25%
Required: phillips head and flat head screw driver, 12mm socket and 10 mm socket (or was it 8mm), #2 allen key, SHORT SHIFT ADAPTER, 1994-1996 honda accord.
Steps:
STEP 1
remove your shift knob first.
center console lift the middle part using your nails or the flat head screw driver. also remove the cup holder by lifting it out.
STEP 2
remove the screws that have been circled
STEP 3
remove the single which is on the right upper corner.
then remove the centre console by lifting it from the back end and basically remove it without breaking anything.
STEP 4
also another picture i missed out on was once the removal of the centre console complete, unscrew 2 screws that hold the surrounding in place. you will be able to see...if i have time ill post pics up.
As you can see, this is the area which will be concentrated on.
STEP 5
now with the 10mm socket remove the bolt which i have pointed to.
be aware its TIGHT
STEP 6
now get the sexi short shift adapter and insert the lil pole into the hole which is just below the holey rod (apart of the vehicle). lso ensure that the allenkey screw is lossened.
http://photobucket.com/albums/a370/d...t=CIMG0150.jpg
STEP 7
now insert the screw bolt in and TURN baby TURN
Pretty isn't it?
STEP 8
now with the bolt that you removed... put it...(follow the picture)
Once that is done, tighten the allenkey screw.
nd wallah
STEP 9
Now ensure that everything is done nice and tightly
BEFORE
AFTER
STEP 10
Now reverse step 1-4 and put your stuff together.
ensure all gears are a-ok.
now go and take it for a drive.. one bad thing.. you'll get use to it in a matter of days and will feel normal until you drive another stock manual accord
Other comments _________________Please understand that this short shift adapter is benefiting comfort for your drive.
-Id like to thank Jenza for being patient sitting here playing with her lil brothers toys-
happy shifting
-Dundas-
